Saltar al contenido principal
Inglés
Español
Paso 7
If the PS4 still does not work after adding two washers you will then remove the heat sink clamp and add a third washer under each heat sink clamp screw. If the PS4 still does not work after adding two washers you will then remove the heat sink clamp and add a third washer under each heat sink clamp screw.
Install 3rd Washer Under Each Screw
  • If the PS4 still does not work after adding two washers you will then remove the heat sink clamp and add a third washer under each heat sink clamp screw.
Si el PS4 todavía no funciona después de agregar dos arandelas, entonces quitará la abrazadera del disipador de calor y agregará una tercera arandela debajo de cada tornillo de sujeción del disipador de calor.
