Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Paso 6
Remove the newly uncovered 2.8 mm screw from the right of the viewfinder using a Phillips #00 screwdriver.
  • Remove the newly uncovered 2.8 mm screw from the right of the viewfinder using a Phillips #00 screwdriver.
  • Remove the 4.9 mm screw from top right of the metal casing on the back using a Phillips #00 screwdriver.
  • Remove the 4.3 mm screw from bottom right of the metal casing on the back using a Phillips #00 screwdriver.
  • Remove the newly uncovered screws from the right of the viewfinder using a Phillips #00 screwdriver. (Note, they're already removed on the picture)
Insertar traducción aquí
