Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Paso 4
Remove the top 2.3 mm screw from the side with the ports using a Phillips #00 screwdriver. Remove the 4 mm screw right below the one you just removed using a Phillips #00 screwdriver.
  • Remove the top 2.3 mm screw from the side with the ports using a Phillips #00 screwdriver.
  • Remove the 4 mm screw right below the one you just removed using a Phillips #00 screwdriver.
Insertar traducción aquí
