Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 25 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 4
Paso 4
Push the battery connector away from the logic board until it stays separated from its socket, so as to avoid any accidental connection to the battery while you work. Push the battery connector away from the logic board until it stays separated from its socket, so as to avoid any accidental connection to the battery while you work.
  • Push the battery connector away from the logic board until it stays separated from its socket, so as to avoid any accidental connection to the battery while you work.
Empuja el conector de la batería lejos de la placa base hasta que se quede separada de su zócalo , a fin de evitar cualquier conexión accidental a la batería mientras trabaja.
