Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 24 guías que incluyan este paso.
Inglés
Español
Paso 2
Opening the display on the 6s Plus separates a thin strip of adhesive around the perimeter of the display. If you prefer to replace the adhesive, have a set of new adhesive strips ready before you continue. It's possible to complete the repair without replacing the adhesive, and you probably won't notice any difference in functionality.
  • Opening the display on the 6s Plus separates a thin strip of adhesive around the perimeter of the display. If you prefer to replace the adhesive, have a set of new adhesive strips ready before you continue. It's possible to complete the repair without replacing the adhesive, and you probably won't notice any difference in functionality.
  • Apply a suction cup to the lower left corner of the display assembly.
  • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
Al abrir la pantalla en el 6s Plus, se separa una delgada tira de adhesivo alrededor del perímetro de la pantalla. Si prefieres reemplazar el adhesivo, ten listo un conjunto de nuevas tiras adhesivas antes de continuar. Es posible completar la reparación sin reemplazar el adhesivo, y probablemente no notarás ninguna diferencia en la funcionalidad.
Aplica una ventosa en la esquina izquierda inferior del ensamblaje de pantalla.
[* icon_note] Opening the display on the 6s Plus separates a thin strip of adhesive around the perimeter of the display. If you prefer to replace the adhesive, have a set of new adhesive strips ready before you continue. It's possible to complete the repair without replacing the adhesive, and you probably won't notice any difference in functionality.
[* black] Apply a suction cup to the lower left corner of the display assembly.
[* icon_note] If your display is badly cracked, [guide|103487|covering it with a layer of clear packing tape|new_window=true] may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
