Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 4 guías que incluyan este paso.
Inglés
Español
Paso 4
The rubber gasket surrounding the home button is very thin and tears easily. Apply mild heat (with an iOpener, heat gun, or hair dryer) to soften the adhesive securing the home button gasket.
  • The rubber gasket surrounding the home button is very thin and tears easily.
  • Apply mild heat (with an iOpener, heat gun, or hair dryer) to soften the adhesive securing the home button gasket.
  • Using your fingertip, gently press up on the home button from the front side of the display assembly. Use firm, constant pressure to slowly separate the home button's rubber gasket from the front panel.
Con la punta del dedo, presiona suavemente hacia arriba el botón de inicio en la parte frontal del ensamblaje de la pantalla para separar lentamente la junta de goma del botón de inicio del panel frontal.
La junta es muy delgada y se rompe fácilmente. Aplica presión constante y dale tiempo para separarse.
[* icon_caution] The rubber gasket surrounding the home button is very thin and tears easily.
[* black] Apply mild heat (with an [product|IF145-198-2|iOpener], heat gun, or hair dryer) to soften the adhesive securing the home button gasket.
black] Using your fingertip, gently press up on the home button from the front side of the display assemblyassembly. Use firm, constant pressure to slowly separate the home button's rubber gasket from the front panel.
[* icon_caution] The gasket is very thin and will tear easily. Apply steady pressure and give it time to separate.
