Saltar al contenido principal
Inglés
Español
Paso 4
This knot will be used for  only the low E, G, and B strings. Insert the springy end of the string into the hole in the tuning peg. Pull the springy end over the tuning peg and to the left side.
Knot the low E, G, and B strings
  • This knot will be used for only the low E, G, and B strings.
  • Insert the springy end of the string into the hole in the tuning peg.
  • Pull the springy end over the tuning peg and to the left side.
  • Bring the springy end to the right side by passing it under the string, creating a loop.
  • Push the springy end through the loop, and then pull both ends until the knot is tight. You may have to press the knot with your finger tighten it completely.
Insertar traducción aquí
