Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 18
The chassis is secured to the bottom cover by two tabs at the front of the unit, two rail and tab sets at the sides of the unit, support posts at the back of the chassis, and hidden brackets that slide into the bottom cover. Step 1:     Press up on one of the front tabs while lifting the support post.                                   Step 2:     Repeat this step on the other side until the internal chassis slides easily toward the back of the computer. Step 1:     Press up on one of the front tabs while lifting the support post.                                   Step 2:     Repeat this step on the other side until the internal chassis slides easily toward the back of the computer.
Internal Chassis
  • The chassis is secured to the bottom cover by two tabs at the front of the unit, two rail and tab sets at the sides of the unit, support posts at the back of the chassis, and hidden brackets that slide into the bottom cover.
  • Step 1: Press up on one of the front tabs while lifting the support post. Step 2: Repeat this step on the other side until the internal chassis slides easily toward the back of the computer.
El chasis está asegurado a la cubierta inferior mediante dos pestañas en la parte frontal de la unidad, dos juegos de rieles y pestañas a los lados de la unidad, postes de soporte en la parte posterior del chasis y soportes ocultos que se deslizan en la cubierta inferior.
Paso 1: presiona hacia arriba una de las pestañas delanteras mientras levantas el poste de soporte. Paso 2: repite este paso en el otro lado hasta que el chasis interno se deslice fácilmente hacia la parte posterior de la computadora.
