Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 5
Grab the main power connector that is connected to the motherboard and pull gradually and firmly toward the power supply. Make sure that you grab the connector, and not the wires, or you will risk damage to the connection.
  • Grab the main power connector that is connected to the motherboard and pull gradually and firmly toward the power supply.
  • Make sure that you grab the connector, and not the wires, or you will risk damage to the connection.
Agarra el conector de alimentación principal que está conectado a la placa base y tira de forma gradual y firme hacia la fuente de alimentación.
Asegúrate de agarrar el conector y no los cables, o te arriesgas a dañar la conexión.
