Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 7 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 3
Paso 3
Rotate it so the display is on your right and the keyboard is on your left. Lift the switch cover firmly but slowly so you do not snap it. Lift the switch cover carefully from one end while sliding the spudger between the switch cover and the laptop to separate them.
  • Rotate it so the display is on your right and the keyboard is on your left.
  • Lift the switch cover firmly but slowly so you do not snap it.
  • Lift the switch cover carefully from one end while sliding the spudger between the switch cover and the laptop to separate them.
  • The switch cover should easily separate from the laptop as you run the spudger through.
Insertar traducción aquí
