Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y Herramientas
Inglés
Español
Paso 3
removing the digitizer. when you put the digitizer in a 90 degrees position , you'll see a flex cable. You can cut it with pliers. the digitizer is loose.
  • removing the digitizer.
  • when you put the digitizer in a 90 degrees position , you'll see a flex cable. You can cut it with pliers.
  • the digitizer is loose.
Insertar traducción aquí
