Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Traduciendo paso 10
Paso 10
Remove the Lightning connector assembly. If your replacement part did not come with a headphone jack gasket, use tweezers to remove the gasket from the old part and transfer it to the replacement part. Before re-installation, use a spudger to scour any remaining adhesive residue from the rear case. You can use high concentration isopropyl alcohol to help with the process.
  • Remove the Lightning connector assembly.
  • If your replacement part did not come with a headphone jack gasket, use tweezers to remove the gasket from the old part and transfer it to the replacement part.
  • Before re-installation, use a spudger to scour any remaining adhesive residue from the rear case. You can use high concentration isopropyl alcohol to help with the process.
Quita el ensamble del conector Lightning.
Si tu pieza de repuesto no incluye un headphone jack gasket, usa unas pinzas para quitar la junta de la pieza vieja y transfiérela a la pieza de repuesto.
Antes de volver a instalarla, usa un spudger para limpiar cualquier resto de adhesivo de la carcasa posterior. Puedes usar alcohol isopropílico de alta concentración para agilizar el proceso.
