Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Paso 6
Insert an opening pick under the Lightning connector flex cable and slowly slice through the adhesive holding the cable to the rear case. Insert an opening pick under the Lightning connector flex cable and slowly slice through the adhesive holding the cable to the rear case. Insert an opening pick under the Lightning connector flex cable and slowly slice through the adhesive holding the cable to the rear case.
  • Insert an opening pick under the Lightning connector flex cable and slowly slice through the adhesive holding the cable to the rear case.
Inserta una púa de apertura bajo el cable flexible del conector Lightning y retira suavemente el adhesivo que sujeta el cable a la carcasa trasera.
