Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 3 guías que incluyan este paso.
Inglés
Español
Paso 3
With the PH 2 screw driver, remove the four rim screws (9.52 x 3.43 mm) located on the outer rim of the metal cover. Next, unscrew the four cover screws (11.91 x 2.89 mm) using the PH 2 screwdriver.
  • With the PH 2 screw driver, remove the four rim screws (9.52 x 3.43 mm) located on the outer rim of the metal cover.
  • Next, unscrew the four cover screws (11.91 x 2.89 mm) using the PH 2 screwdriver.
Insertar traducción aquí
