Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y herramientas
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Paso 2
Remove the following two screws: One 3.3 mm Phillips screw One 2.1 mm Phillips screw
  • Remove the following two screws:
  • One 3.3 mm Phillips screw
  • One 2.1 mm Phillips screw
  • Lift the metal retainer clip straight up from its recess in the rear panel.
  • Be sure the small thermal pad is attached to the metal retaining clip as seen in the third picture when replacing the rear facing camera.
Insertar traducción aquí
