Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 3 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 5
Paso 5
Using the spudger, loosen the casing behind the battery and the two sides. The case should lift easily upwards and outwards towards you if you are facing the battery compartment.
  • Using the spudger, loosen the casing behind the battery and the two sides.
  • The case should lift easily upwards and outwards towards you if you are facing the battery compartment.
  • Make sure the cord that was attached to the Bluetooth cable is not still threaded through the case when trying to remove it.
  • If you feel any resistance, stop. Do not force anything. Go back through the steps and make sure you loosened everything.
Insertar traducción aquí
