Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando un prerrequisito para la guía que estabas viendo. Cualquier cambio que realices afectará la guía que incluye este paso.
Inglés
Español
Paso 5
First pull up on one side of the power supply, then pull up on the other side. Gently but firmly wiggle it out. Be careful as you pull up on the power supply as it is still connected with a connector from the motherboard. Be careful as you pull up on the power supply as it is still connected with a connector from the motherboard.
Remove Power Supply
  • First pull up on one side of the power supply, then pull up on the other side. Gently but firmly wiggle it out.
  • Be careful as you pull up on the power supply as it is still connected with a connector from the motherboard.
Primero jala hacia arriba en un lado de la fuente de alimentación, luego tira hacia arriba en el otro lado. Suavemente pero con firmeza sacúdelo.
Ten cuidado al tirar de la fuente de alimentación, ya que todavía está conectado con un conector de la placa base.
