Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y herramientas
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 13 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Remove the following 3 screws:
  • Remove the following 3 screws:
  • Two 3 mm Phillips near the right speaker.
  • One 6 mm Phillips threaded through a hole in a plastic finger above the subwoofer.
  • Be careful not to over-tighten the screw above the subwoofer too tight or the plastic could crack.
  • Santa Rosa and Penryn MacBooks do not have a c-channel. If you are disassembling either of these models, remove only the single 3 mm Phillips screw from the right speaker and skip step 26.
Insertar traducción aquí
