Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 6 guías que incluyan este paso.
Inglés
Español
Paso 2
Turn the Lombard so that the trackpad is nearest you and slide the thin plastic shield away from you, out from under the black casing.
  • Turn the Lombard so that the trackpad is nearest you and slide the thin plastic shield away from you, out from under the black casing.
  • Disconnect the newly revealed thin orange ribbon from the logic board, to the left of the trackpad.
  • Remove the two long silver Torx screws.
Insertar traducción aquí
