Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Inglés
Español
Paso 11
We turn back to the metal casing to extract the pen nib and look for its sensor magic. Peeling up one of the tiniest boards we've ever seen we find a set of three matching ticks. Three on the end of the pen assembly, and three on the tiny board. If we had to hazard a guess, we'd say these helped sense pressure by measuring movement between these two parts.
  • We turn back to the metal casing to extract the pen nib and look for its sensor magic.
  • Peeling up one of the tiniest boards we've ever seen we find a set of three matching ticks. Three on the end of the pen assembly, and three on the tiny board.
  • If we had to hazard a guess, we'd say these helped sense pressure by measuring movement between these two parts.
  • Chances are this chip could tell us more about how this works...
  • It reads 8529043 343S00008-A1
Regresamos a la carcasa de metal para extraer la punta de la pluma y buscar su sensor mágico.
Pelando una de las tablas más pequeñas que hemos visto, encontramos un conjunto de tres tics coincidentes. Tres en el extremo del ensamblaje de la pluma y tres en la pequeña placa.
Si tuviéramos que arriesgarnos a adivinar, diríamos que esto ayudó a sentir la presión al medir el movimiento entre estas dos partes.
Lo más probable es que este chip pueda decirnos más sobre cómo funciona esto ...
Se lee 8529043 343S00008-A1
