Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Inglés
Español
Paso 4
Taking a nosedive into the Pencil, we start at the nib, which comes off quietly with a few quick twists. A peek inside reveals a tiny metal bit sunk deeply into the tip, presumably to get as close to the screen as possible. This likely connects to one of the two emitters in the tip that allow the iPad Pro to determine the Pencil's angle and orientation relative to the display, and adjust the pen stroke accordingly.
  • Taking a nosedive into the Pencil, we start at the nib, which comes off quietly with a few quick twists.
  • A peek inside reveals a tiny metal bit sunk deeply into the tip, presumably to get as close to the screen as possible.
  • This likely connects to one of the two emitters in the tip that allow the iPad Pro to determine the Pencil's angle and orientation relative to the display, and adjust the pen stroke accordingly.
  • The digitizer on an iPad Pro should be able to determine the distance from each emitter to the screen—and from that calculate the angle of the Pencil relative to the iPad.
Echando un vistazo al lápiz, comenzamos por la punta, que sale silenciosamente con unos pocos giros rápidos.
Una mirada al interior revela una pequeña broca de metal hundida profundamente en la punta, probablemente para acercarse lo más posible a la pantalla.
Es probable que esto se conecte a uno de los dos emisores en la punta que permite al iPad Pro determinar el ángulo y la orientación del Lápiz en relación con la pantalla, y ajustar el trazo de la pluma en consecuencia.
El digitalizador en un iPad Pro debe poder determinar la distancia de cada emisor a la pantalla y, a partir de eso, calcular el ángulo del lápiz en relación con el iPad.
