Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Inglés
Español
Paso 10
One last module to crack open—while it's only marked with a microphone icon, there are actually quite a few components in here. The vibration motor and loudspeaker are connected by spring contacts—more easily removed parts, yay!
  • One last module to crack open—while it's only marked with a microphone icon, there are actually quite a few components in here.
  • The vibration motor and loudspeaker are connected by spring contacts—more easily removed parts, yay!
  • The USB port and microphone are soldered to the board—not necessarily a bad thing, as a USB port requires some extra rigidity, and has significantly more pins than a speaker.
Un módulo más para abrir —si bien solo está marcado con un icono de micrófono, hay en realidad bastantes componentes allí.
El motor de vibración y el altavoz están conectados por contactos de muelle—más partes fáciles de remover. ¡Bravo!
El puerto USB y el micrófono están soldados a la placa—no necesariamente algo malo, ya que un puerto USB requiera algo de rigidez adicional y tiene significativamente más clavijas que un altavoz.
