Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 4 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 2
Paso 2
Once the 1mm screw is removed, reinsert  the metal screwdriver in that same hole. Gently push the strap's pin out. It will begin to protrude from the other end.
  • Once the 1mm screw is removed, reinsert the metal screwdriver in that same hole.
  • Gently push the strap's pin out. It will begin to protrude from the other end.
  • Use your fingers to grab the exposed pin and slide it free. The strap should now be disconnected from the device.
Insertar traducción aquí
