Saltar al contenido principal
Inglés
Español
Traduciendo paso 1
Paso 1
Release the ribbon cables using the plastic opening tool to flip the gray tab on the white connector. Gently slide ribbon cable out while gray tab is flipped up. If glued, go ahead and peel ribbon from hard drive.
  • Release the ribbon cables using the plastic opening tool to flip the gray tab on the white connector.
  • Gently slide ribbon cable out while gray tab is flipped up.
  • If glued, go ahead and peel ribbon from hard drive.
Insertar traducción aquí
