Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 2 guías que incluyan este paso.
Inglés
Español
Paso 6
Unscrew the 4mm screw from the WWAN card with a Phillips screwdriver.  The card will lift itself after you do so Gently pull out the WWAN card Gently pull out the WWAN card
  • Unscrew the 4mm screw from the WWAN card with a Phillips screwdriver. The card will lift itself after you do so
  • Gently pull out the WWAN card
Insertar traducción aquí
