Saltar al contenido principal
Inglés
Español
Paso 7
Keys can be removed from the board by pulling them upward with your fingers. Larger keys can be removed by lifting the key away to expose the metal pin underneath for added support. Detach the pin by pulling out from the plastic tabs holding the pin using tweezers. Larger keys can be removed by lifting the key away to expose the metal pin underneath for added support. Detach the pin by pulling out from the plastic tabs holding the pin using tweezers.
  • Keys can be removed from the board by pulling them upward with your fingers.
  • Larger keys can be removed by lifting the key away to expose the metal pin underneath for added support. Detach the pin by pulling out from the plastic tabs holding the pin using tweezers.
Insertar traducción aquí
