Saltar al contenido principal
Inglés
Español
Paso 2
Use the plastic opening tool to remove the rubber pads at each corner. Once removed, there are 10mm screws below each pad. Remove the screws using the phillips-head screwdriver. Once removed, there are 10mm screws below each pad. Remove the screws using the phillips-head screwdriver.
  • Use the plastic opening tool to remove the rubber pads at each corner.
  • Once removed, there are 10mm screws below each pad. Remove the screws using the phillips-head screwdriver.
Insertar traducción aquí
