Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Traduciendo paso 5
Paso 5
Remove the battery.
Adhere the battery, disconnect it, and continue reassembling your device.
[* black] Remove the battery. |
[* icon_note] If your replacement battery came in a plastic sleeve, remove the sleeve before installation by pulling it away from the the ribbon cable. |
[* icon_reminder] If there's any alcohol solution remaining in the phone, carefully wipe it off or allow it to air dry before installing your new battery. |
[* icon_reminder] Before you adhere the replacement battery, temporarily reconnect the battery connector to the logic board socket. This ensures that the battery is properly aligned in its recess. |
[* black] Adhere the battery, disconnect it, and continue reassembling your device. |
[* icon_reminder] If your new battery doesn’t have adhesive preinstalled, refer to [guide|56465|this guide] to replace the adhesive strips. |
[* icon_reminder] Perform a [guide|62336|hard reset] after reassembly. This can prevent several issues and simplify troubleshooting. |
