Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Traduciendo paso 4
Paso 4
Alternative methods to unstick the battery from the case
Prepare an iOpener and apply it to the back of the rear case, directly over the battery. Otherwise, you can apply heat using a heat gun or hair dryer.
Thread the floss or string behind the upper battery corners, bring the ends together, wrap them around a folded cloth, and pull evenly.
[title] Alternative methods to unstick the battery from the case |
[* icon_note] '''If you successfully removed all three adhesive strips, move on to the next step. '''Otherwise, you will need to pry the battery from the rear case. |
[* black] [guide|25705|Prepare an iOpener|new_window=true] and apply it to the back of the rear case, directly over the battery. [* black] After about a minute, flip [* icon_caution] Overheating the [* icon_caution] Don't try to forcefully lever the battery out. If needed, apply a [* icon_caution] '''Do not''' insert [* icon_caution] [* icon_caution] Keep the card as flat as possible to avoid bending the battery, which may damage it and cause it to release dangerous chemicals or catch fire. Do not use any sharp tools to pry at the battery. |
[* icon_note] Alternatively, a piece of dental floss may be used to separate the battery from the rear case. A stronger alternative to dental floss is an unwound guitar string, such as a 0.009 E string from a 12-string set. |
