Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Paso 3
Gently pull the battery adhesive tabs away from the battery, toward the bottom of the iPhone. To avoid tearing the adhesive strip, be careful not to pull against the battery or lower components. Pull steadily, maintaining constant tension on the strips as they slip out from between the battery and the rear case. For best results, pull the strips at a 60º angle or less.
  • Gently pull the battery adhesive tabs away from the battery, toward the bottom of the iPhone.
  • To avoid tearing the adhesive strip, be careful not to pull against the battery or lower components.
  • Pull steadily, maintaining constant tension on the strips as they slip out from between the battery and the rear case. For best results, pull the strips at a 60º angle or less.
  • The strips will stretch to many times their original length. Continue pulling and re-grab the strips near the battery if necessary.
  • Hold down the battery with one hand as you pull, or the elastic strips may fling the battery from the phone once they're separated from the rear case.
  • If the adhesive breaks off underneath the battery and can't be retrieved, refer to the previous step for instructions on how to unstick the battery. See the next step for additional methods.
Retira suavemente las lengüetas adhesivas de la batería de la batería, hacia la parte inferior del iPhone.
Para evitar rasgar la tira adhesiva, ten cuidado de no tirar contra la batería o los componentes inferiores.
Tira firmemente, manteniendo una tensión constante en las tiras mientras se deslizan entre la batería y la caja trasera.
Para obtener los mejores resultados, tira de las tiras en un ángulo de 60 ° o menos. Las tiras se extenderán a muchas veces su longitud original. Continúa tirando y vuelve a agarrar las tiras cerca de la batería si es necesario. .
Manten presionada la batería con una mano mientras tira, o las tiras elásticas pueden arrojar la batería del teléfono una vez que están separados de la caja trasera
[* black] Gently pull the battery adhesive tabs away from the battery, toward the bottom of the iPhone.
[* icon_caution] To avoid tearing the adhesive strip, be careful not to pull against the battery or lower components.
[* black] Pull steadily, maintaining constant tension on the strips as they slip out from between the battery and the rear case. For best results, pull the strips at a 60º angle or less.
[* icon_note] The strips will stretch to ''many'' times their original length. Continue pulling and re-grab the strips near the battery if necessary.
[* icon_caution] Hold down the battery with one hand as you pull, or the elastic strips may fling the battery from the phone once they're separated from the rear case.
[* icon_note] If the adhesive breaks off underneath the battery and can't be retrieved, refer to '''the previous step''' for instructions on how to unstick the battery. See '''the next step''' for additional methods.
