Saltar al contenido principal
Inglés
Español
Traduciendo paso 1
Paso 1
The battery is glued down, usually with double-sided tape along the sides. The goal is to lift the battery out by pulling on the folded white tab in the top right corner. It may be necessary to first loosen the adhesive by running a flat, thin plastic tool under the edges of the battery. Be careful when lifting the battery out, it is still connected to the device.
  • The battery is glued down, usually with double-sided tape along the sides. The goal is to lift the battery out by pulling on the folded white tab in the top right corner. It may be necessary to first loosen the adhesive by running a flat, thin plastic tool under the edges of the battery.
  • Be careful when lifting the battery out, it is still connected to the device.
Insertar traducción aquí
