Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 8 guías que incluyan este paso.
Inglés
Español
Paso 18
Tip the logic board up to a vertical position to expose the single antenna connector on the underside, near the top edge of the board. Do not attempt to fully remove the logic board yet, as the Wi-Fi/Bluetooth antenna is still connected to the underside of the board. Do not attempt to fully remove the logic board yet, as the Wi-Fi/Bluetooth antenna is still connected to the underside of the board.
  • Tip the logic board up to a vertical position to expose the single antenna connector on the underside, near the top edge of the board.
  • Do not attempt to fully remove the logic board yet, as the Wi-Fi/Bluetooth antenna is still connected to the underside of the board.
Inclina la placa lógica hacia arriba en posición vertical para exponer el único conector de antena en la parte inferior cerca del borde superior de la placa.
No intentes aun de remover por completo la placa lógica, ya que la antena Wi-Fi/Bluetooth está todavía conectada al lado inferior de la placa.
