Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 8 guías que incluyen este paso.
Inglés
Español
Paso 19
Gently lay the logic board upside-down, with the top portion resting against the rear case of the iPhone. Use the flat end of the spudger to disconnect the Wi-Fi/Bluetooth antenna cable from its socket on the back of the logic board.
  • Gently lay the logic board upside-down, with the top portion resting against the rear case of the iPhone.
  • Use the flat end of the spudger to disconnect the Wi-Fi/Bluetooth antenna cable from its socket on the back of the logic board.
Con cuidado coloca la placa lógica dada vuelta con la porción superior contra la caja del iPhone.
Usa el extremo plano de un spudger para desconectar el cable de antena Wi-Fi/Bluetooth de su zócalo en la parte posterior de la placa lógica.
