Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 2 guías que incluyan este paso.
Inglés
Español
Paso 4
If you successfully removed all three adhesive strips, move on to the next step. Otherwise, you will need to pry the battery from the rear case. Prepare an iOpener and apply it to the back of the rear case, directly over the battery. Alternatively, you can apply heat using a heat gun or  hair dryer.
  • If you successfully removed all three adhesive strips, move on to the next step. Otherwise, you will need to pry the battery from the rear case.
  • Prepare an iOpener and apply it to the back of the rear case, directly over the battery. Alternatively, you can apply heat using a heat gun or hair dryer.
  • After about a minute, flip the phone over and use a plastic card to break up any remaining adhesive behind the battery.
  • Do not insert your card in the area between the volume down (-) button and the top edge of the battery, or you may damage the volume control cable lying underneath.
  • Do not pry against the logic board or you may damage the phone.
  • Keep the card as flat as possible to avoid bending the battery, which may damage it and cause it to release dangerous chemicals or catch fire. Do not use any sharp tools to pry at the battery.
  • Alternatively, a piece of dental floss may be used to separate the battery from the rear case. A stronger alternative to dental floss is an unwound guitar string, such as a 0.009 E string from a 12-string set.
  • Thread the floss or string behind the upper battery corners, bring the ends together, wrap them around a folded cloth, and pull evenly.
Si eliminaste con éxito las tres tiras adhesivas, continúa con el siguiente paso. De lo contrario, deberás sacar la batería de la caja trasera.
Prepara un iOpener y aplíquelo a la parte posterior de la caja trasera, directamente sobre la batería. Alternativamente, puedes aplicar calor usando una pistola de calor o un secador de pelo.
Después de aproximadamente un minuto, da vuelta el teléfono y usa una tarjeta de plástico para romper el adhesivo restante detrás de la batería.
No insertes tu tarjeta en el área entre el botón para bajar el volumen (-) y el borde superior de la batería, o puedes dañar el cable de control de volumen que se encuentra debajo.
No hagas palanca contra la placa lógica o puedes dañar el teléfono.
Mantén la tarjeta lo más plana posible para evitar doblar la batería, lo que puede dañarla y hacer que libere sustancias químicas peligrosas o que se incendie. No uses herramientas afiladas para hacer palanca en la batería.
Alternativamente, se puede usar un hilo dental para separar la batería de la caja trasera. Una alternativa más fuerte al hilo dental es una cuerda de guitarra desenrollada, como una cuerda 0.009 E de un conjunto de 12 cuerdas.
Pasa el hilo dental o la cuerda detrás de las esquinas superiores de la batería, junte los extremos, envuélvelos alrededor de un paño doblado y tira uniformemente.
