Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Traduciendo paso 3
Paso 3
Lift the battery out of the case. Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery. To install a new battery:
  • Lift the battery out of the case.
  • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
  • To install a new battery:
  • Remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
  • Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the phone, not directly onto the battery. The adhesive should go around the perimeter of the battery compartment, but not in the rectangular cutout in the center (which is actually the back side of the display).
  • Press the battery firmly into place for 5-10 seconds.
Insertar traducción aquí
