Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 3 guías que incluyan este paso.
Inglés
Español
Paso 2
After the cover has been removed, unscrew the M1.6 x 2mm screw from the battery cable with a j000 Philips head bit. Using screwdriver bits that do not fit snugly in the screw head have a tendency to strip the screw and render it unusable. Remove the tape by gently scraping the edges up with a spudger.
  • After the cover has been removed, unscrew the M1.6 x 2mm screw from the battery cable with a j000 Philips head bit.
  • Using screwdriver bits that do not fit snugly in the screw head have a tendency to strip the screw and render it unusable.
  • Remove the tape by gently scraping the edges up with a spudger.
Insertar traducción aquí
