Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 21 guías que incluyan este paso.
Inglés
Español
Paso 5
Make sure the battery is disconnected before you disconnect or reconnect the cable in this step. Disconnect the home button/fingerprint sensor cable by prying it straight up from its socket on the logic board.
  • Make sure the battery is disconnected before you disconnect or reconnect the cable in this step.
  • Disconnect the home button/fingerprint sensor cable by prying it straight up from its socket on the logic board.
Asegúrate de que la batería está desconectada antes de desconectar o reconectar el cable en este paso.
Desconectar el cable de pantalla levantándolo de su zócalo en la placa lógica.
[* icon_caution] Make sure the battery is disconnected before you disconnect or reconnect the cable in this step.
[* black] Disconnect the displayhome button/fingerprint sensor cable by prying it straight up from its socket on the logic board.
