Saltar al contenido principal
Inglés
Español
Traduciendo paso 1
Paso 1
Once you have removed the motherboard and the battery, locate both the upper and lower speakers. The lower speaker wire is glued to the back casing of the device, so be gentle when removing the wire. Lift up the wire with a plastic opening tool. Make sure this tool has a sharp edge.
  • Once you have removed the motherboard and the battery, locate both the upper and lower speakers.
  • The lower speaker wire is glued to the back casing of the device, so be gentle when removing the wire.
  • Lift up the wire with a plastic opening tool. Make sure this tool has a sharp edge.
Insertar traducción aquí
