Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Inglés
Español
Traduciendo paso 23
Paso 23
iPad 2 Repairability Score: 2 out of 10 (10 is easiest to repair) The LCD is really easy to remove once the front panel is gone.
  • iPad 2 Repairability Score: 2 out of 10 (10 is easiest to repair)
  • The LCD is really easy to remove once the front panel is gone.
  • Only standard Phillips screws were used -- no Pentalobular or Tri-Wing funny-business.
  • The front panel is now glued to the rest of the device, greatly increasing the chances of cracking the glass when trying to remove it.
  • The LCD has foam sticky tape adhering it to the front panel, increasing chances of it being shattered during disassembly.
  • The battery is very securely stuck down to rear case, and you have to remove the logic board to remove it.
  • You can't access the front panel's connector until you remove the LCD.
  • Historical note: We initially awarded the iPad 2 a 4 out of 10, but in the process of writing our repair manual realized that it was far more difficult to repair than originally suspected.
Insertar traducción aquí
