Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Traduciendo paso 12
Paso 12
The last step is to separate the plastic frame from the old Digitizer glass. I recommend using a heat gun to heat up the glue and then easily separate the old digitizer.
Last step
  • The last step is to separate the plastic frame from the old Digitizer glass.
  • I recommend using a heat gun to heat up the glue and then easily separate the old digitizer.
  • You are now ready to put your new digitizer on the plastic frame and assemble the T-100.
  • BE VERY careful when applying heat to the plastic, it can easily bend so make sure you keep your heatgun/hairdryer on low heat.
Insertar traducción aquí
