Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 10 guías que incluyan este paso.
Inglés
Español
Paso 4
Use the edge of a plastic opening tool to disconnect the Wi-Fi antenna cable connector from the logic board.
  • Use the edge of a plastic opening tool to disconnect the Wi-Fi antenna cable connector from the logic board.
  • When reconnecting the wifi ribbon connector to the mother board be VERY certain that the round connector at the end of the ribbon cable is centered on its mating half on the motherboard before applying pressure. Failure to do so will likely destroy both halves of the connection.
Insertar traducción aquí
