Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo. Cualquier cambio que realices afectará la guía que incluye este paso.
Inglés
Español
Traduciendo paso 12
Paso 12
Remove the display assembly from the iPhone. Be sure to separate the home button from the front panel. If the home button sticks to the front panel you may tear the home button cable.
  • Remove the display assembly from the iPhone.
  • Be sure to separate the home button from the front panel. If the home button sticks to the front panel you may tear the home button cable.
  • When replacing the display assembly, note the following:
  • You may have to reuse the earpiece grille and the clear plastic ring around the front facing camera from the old/damaged assembly. This will depend on where you buy the replacement part.
  • Your replacement display may come with colored plastic film on the back of the LCD. If so, use the pull tab near the home button to peel the plastic film from the LCD before installing the new display in your iPhone.
  • After reassembly, note the following:
  • Clean the touchscreen surface with an alcohol wipe prior to turning the iPhone back on. The alcohol helps dissipate any lingering static electricity, which can cause problems with the display.
  • After reassembly, connect the iPhone to an AC power source before turning it on for the first time. Once the iPhone has booted up successfully, you can disconnect the AC power.
Insertar traducción aquí
