Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 4 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Use tweezers to gently disconnect the connections that run across the battery and are connected to the motherboard. Proceed to gently remove the tape like connector from the battery until it is completely off. Use tweezer to disconnect battery’s wire from the motherboard.
  • Use tweezers to gently disconnect the connections that run across the battery and are connected to the motherboard.
  • Proceed to gently remove the tape like connector from the battery until it is completely off.
  • Use tweezer to disconnect battery’s wire from the motherboard.
Insertar traducción aquí
