Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 5 guías que incluyan este paso.
Inglés
Español
Paso 2
Using the flat metal spudger and curved metal spudger, make a wedge between the plastic back cover and the inner frame Using the second spudger, slowly work your way around the perimeter of the device Listen for clicking sounds as you are prying the back cover away from the frame
  • Using the flat metal spudger and curved metal spudger, make a wedge between the plastic back cover and the inner frame
  • Using the second spudger, slowly work your way around the perimeter of the device
  • Listen for clicking sounds as you are prying the back cover away from the frame
  • As the back cover is almost completely removed, use the suction-cup tool to remove the plastic cover without damaging the back
Insertar traducción aquí
