Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y Herramientas
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Use a pair of tweezers to disconnect the ribbon cable from the ZIF connector by flipping up the black retaining flap. You should then be able to pull the cable free. Once the ribbon cable is disconnected, you can remove the black plastic bracket which holds the camera lens.
  • Use a pair of tweezers to disconnect the ribbon cable from the ZIF connector by flipping up the black retaining flap. You should then be able to pull the cable free.
  • Once the ribbon cable is disconnected, you can remove the black plastic bracket which holds the camera lens.
  • Be careful removing the ribbon cable. It is very fragile and can tear.
Insertar traducción aquí
