Saltar al contenido principal
Fix Your Stuff
Right to Repair
Parts & Tools
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Paso 6
Flip the motherboard over. The speaker assembly should be loose and only connected by two wires leading to a white connector.
  • Flip the motherboard over. The speaker assembly should be loose and only connected by two wires leading to a white connector.
  • Using the metal tweezers, pull upwards to disconnect the connector from its port.
  • Use caution when prying on the connector. It is made of breakable plastic, and it requires significant force to be removed. try to apply an evenly distributed force when removing the connector.
Insertar traducción aquí
