Saltar al contenido principal
Inglés
Español
Paso 20
With the logic board facing down, push the pins of the new connector through the holes in the logic board, making sure each pin goes through the board. DO NOT use excessive force, as you can bend the pins. DO NOT use excessive force, as you can bend the pins.
  • With the logic board facing down, push the pins of the new connector through the holes in the logic board, making sure each pin goes through the board.
  • DO NOT use excessive force, as you can bend the pins.
Insertar traducción aquí
