Saltar al contenido principal
Inglés
Español
Paso 19
Once all solder is removed, pry the dock connector straight down from the logic board using a metal spudger. DO NOT remove the dock connector before all solder is removed, as the pins will rip from the dock connector and get stuck in the logic board.
  • Once all solder is removed, pry the dock connector straight down from the logic board using a metal spudger.
  • DO NOT remove the dock connector before all solder is removed, as the pins will rip from the dock connector and get stuck in the logic board.
  • If done properly, you should be able to see straight through the logic board where all 30 pins and the two metal joints used to be.
Insertar traducción aquí
