Saltar al contenido principal
Inglés
Español
Paso 15
The wifi cable is connected to the bottom of the logic board by a small connector.  This must be disconnected before removing the logic board from the case. Insert the edge of a metal spudger under the logic board, between the wifi cable connector clip and the logic board. Gently pry the connector from the logic board.
  • The wifi cable is connected to the bottom of the logic board by a small connector. This must be disconnected before removing the logic board from the case.
  • Insert the edge of a metal spudger under the logic board, between the wifi cable connector clip and the logic board.
  • Gently pry the connector from the logic board.
Insertar traducción aquí
