Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 4 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 6
Paso 6
Disconnect the battery using tweezers or your fingernails. The battery is glued down, if available put some isopropyl alcohol around the edges of the battery to soften the glue.
  • Disconnect the battery using tweezers or your fingernails.
  • The battery is glued down, if available put some isopropyl alcohol around the edges of the battery to soften the glue.
  • Gently pry of the battery lose using a spudger or another thin prying tool.
  • Be careful, damaging/puncturing the battery may cause an explosion.
Insertar traducción aquí
